yes you can, but it depends on the size of the existing rainwater pipe as to if you can get a suitable size "adaptor" also the cast iron pipe will rust from the inside out, why not change the whole lot now rather than wait untill winter when you find the existing pipe has got another hole in it.
Depending on your area some local planning will not let you switch from cast iron to plastic pipe in conservation area and storm water must go to soakaway. (I give up!)
I have 2 cast iron rainwater downpipes to replace. One of them goes into a freshwater drain (well, it goes 6 inches to the left of the drain and needs moving) the other empties onto the concrete surface adjacent to my exterior wall - hence damp problems.
aaront, where are you based? I need a re-cliamed cast iron end piece as I "managed" to swip the end off one whilst trimming a yew tree. Doh! Would be interested in buying one to replace. House bulit 1935.
