Raising roof of flat roof extension
5 May 2019
I have a 70s flat roof extension with brick inner and Bradstone outer skin. It has very low ceiling height which I want to improve by adding say a 2-3 brick courses or one course of conrete blocks. Atop this will be a new warm roof. The new masonry will be hidden by a deeper fascia. Location and aspect of the extension mean that the aesthetics of a deep fascia are not a concern.
The existing roof joists rest directly (at right angles) on a wooden window frame about 2.4m wide. This will be replaced by uPVC. Original plan is to put a catnic style lintel across the window opening. The problem is that, in the midst of the covid-19 lockdown, I cannot find anywhere that is open, has stock and can deliver (south-east Warks), but have plenty of time on my hands.
I can find timber suppliers still operating, so would a timber lintel be a viable option?
Would it be feasible to create the entire height addition in timber as part of the new roof construction?
OP,
For what you are trying to achieve you will have inconvenience and expense that dont seem to be justified in terms of your proposal?
At first glance at your post I'd suggest why not consider demolition, and re-build with a pitched roof if possible?
I omitted to say it's a bungalow. Marrying a pitched roof to the existing roof is a whole new level of pain. Similarly, demolishing and rebuilding is a lot more work.
I am happy with the expense for what I am trying to achieve. The inconvenience is current (low ceiling height) and will be solved by what I want to do.
OP,
you can do more or less anything in the building line to existing buildings - if you wish to pay for it.
In your case, you wil be running a raised extension flat roof back into a bungalow, presumably, pitched roof.
How the roof is raised is almost irrelevant - my point was that the comparative costs of re-modelling or re-building are usually worth considering.
fwiw: at house sale time buyers and surveyors dont like the unusual.
The first floor flat roof extension below, was added onto an existing ground floor flattie. It was going to be cladded so I suggested building the whole thing in stud etc but the customer actually wanted it built in matching brick, just in case any future owners wanted to remove the cladding.
