hi
I have just moved into a property that was a repossession so the water and central heating system had been drained.
The boiler is a gas powered range powermax 155x and the central heating is open vented.
I refilled the system and bled the air our of the radiators, I then switched on the boiler according to the manual. The indicators on the boiler showed that the boiler had ignited and the hot water and central heating were on but I only got hot water and all the radiators remained cold. I turned up the thermostat in the lounge which appeared to engage the pump for the central heating (I could hear a whirring sound from the boiler which i assume was the pump) and left this for about 20 minutes but still the radiators remained cold.
Is there anything i have missed in the refiling procedure or is there potentially a problem with the system/ boiler? any ideas would be helpful.
I have read something in another forum about blowing into the vent pipe in the expansion tank to make sure the boiler is filled properly but I don't know if that is applicable to this problem.
Many thanks in advance for your help
John
John
