i dont think they would make a boiler that blasted 30kw from the start, most if not all would have a soft start then build up to the max rate, range rating the boiler just helps to run the boiler in the most efficient way.
i don't know if the baxi 105he can be range rated.
i know biasi and heat-line do.
biasi from the control panel from the front and heat-line has a pot on the pcb
