Range Tribune He no hot water
28 Aug 2013
Cheshire
hello, found this good forum I hope someone will be able to help me. I will try to explain my problem.
One weak ago how water just disappear..... before have no problems with hot or cold water.... I'll tried everything, bought power tester everything look's fine but we still have no hot water only cold.... you are the last hope, if I will not find a solution, I will need to call for plumber....
i will meke some photos of all my system.
It looks to me like that is a Pressurised cylinder (like a Megaflo) in which case you will need a "plumber" with a certificate to work on them (this is required because it is possible, but very unlikely, for them to become dangerous in unskilled hands). This is also why you are best not to DIY it. You have already checked the breakers in your consumer unit, and any switches, fuses and timers, I presume. I gather from what you say that neither the upper nor the lower heater is working. You do not mention a gas boiler.
If you ask around for a good local plumber or heating engineer, and mention the name and other details on the ID plate, ask if they are certified when you call.
The Yellow Pages are not a good way to find a good person, but the "Check a recommended trade" websites are even worse as they usually are paid by the traders.
