Rangemaster Classic 90 dual fuel ignitor problem
15 Jun 2004
Norwich
I have Rangemaster Classic 90, this has 5 burners.
The electrode for the wok sparks ok.
The other 4 no spark, are there 2 Ignition generators (and 1 has failed) or is there just the 1 & maybe a lead has come off?
Any help appreciated.
If it's the same as ours I'm pretty sure all the wires are connected by spade terminals, so by swapping them about you could prove what's working and what's not.
Your posts are confusing, your first post says only one ignitor working, the second says 4 ignitors are working. A quick resistance check between the electrode & each wire terminal at the other end will tell you if it is the ignition unit that is faulty or the other components.
@jj4091, sorry I missed the word 'NOT'
Seems to be ok now, I think the lady that cleaned it flooded the electrodes, or of course it could be an intermittent fault.
Thanks: freddo & alan333
Probably your first thought, it's the most common cause, next to pans boiling over.
