- Joined
- 27 Jan 2008
- Messages
- 29,961
- Reaction score
- 3,733
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I would have thought it there is an issue with a web page, then the way forward would be to remove the page until corrected, not continue to publish a page with incorrect information. We all make mistakes, as a result we put in methods to reduce the effect of the errors, as electricians the inspection and testing of our own work once completed we hope will highlight any mistakes which will be then corrected before we power up, any publishing house will employ proof readers to try and find then highlight any errors before the work is published.
Our electrical system is complex, any attempt to simplify will result in errors, under "Adding a power socket" it lists.
Things you’ll need
Circuit tester
Power socket mounting box
Power socket cover plate
Screwdriver
Screws
Wire stripper
Now I would want to test with something a little more than a "Circuit tester" and I would also put using the tester before removing the socket not after, using names like "Power socket cover plate" is asking for problems, I would consider the cover plate as part of a grid switch arrangement not a simple socket. Comments like "Wrap the wires around each terminal and tighten the screw with a screwdriver." again makes me think this was not done for UK sockets, but adapted from some other countries system. However I don't know which country uses "the blue wire to the ground terminal"?
down to earth advice blue
Is rather a serious error, the "grounding wire" makes me feel this was originally written for the USA and some one has failed to change it for UK? It does raise serious questions as to the whole organisation that this is still on their website.Rated People web site said:You should see three wires: the neutral wire (black wire), live wire (red wire), and grounding wire (blue wire).
Things you’ll need
Circuit tester
Screwdriver
Screws
Wire stripper
There was a famous quote "Let him have it" which the person who said it claimed meant to tell the other person to give the gun, but the court considered he was telling the other person to shoot the gun, and he was hanged as a result. Had the guy said nothing he would not have been hanged. So if the rated people don't want you to follow their advice the way to do it is not to publish it. And small print is not really going to help them should some one follow their advice.Rated People web site said:Please note that all our DIY guides and ‘Expert answers’ advice have been written strictly for reference only. Rated People do not accept any liability for any damage caused to an individual, property or anything else as a result of following our DIY guides and using our ‘Expert answers’ advice.
