Hiya all - I have a Ravenheat 80T and had a small problem with it of late...
Boiler refused to startup either on timer or demand, well it did start but in it's own time, ie you'd turn it on and nothing would happen then anytime later it will start up as normal but then would only stay on for any amount of time and cut out again.
So I took a look inside,
Checked the timer with an AVO or multimeter to be up to date all ok there.
Took the Air Pressure Switch off and checked/cleaned it and put it back on and now I have a whistling noise coming from it when boiler is on and working...
Does this need replacing and could it be part of the cutting out problem on both DHW & CH...???
Also with this other problem, ie the cutting out, not starting up etc, well when i wiggle the CH sensor connector / sensor around, the boiler fires up as normal, wiggle it again and it shuts down so I'm pretty certain it's that... ???? I've measured the resistance but totally forgot what it was now
Would this stop the boiler working it it was buggered ??? How much are they and do I have to drain the system to replace (looks like a 13 mm socket to undo it)
Many many thanks in advance....
Colin
Colin
