Just had this installed. The auto air vent cap is missing, the mains inlet to heat exchanger connector leaked and the pump was stuck. Apart from that the boiler is now workring except it takes about 10 seconds from turning a tap on to the burner igniting. Trying to save energy with a condensing boiler and waste a load of water waiting for it to heat up!
Is there a way to adjust this? The troubleshoot in manual isn't very extensive e.g. does it work - Yes then you're OK, No - is it switched on.
