Ravenheat 85T
27 Nov 2009
Any help pls
Boiler starts up on heating but goes into on/off on main burner continuously
If I turn on domestic hot water it runs normaly until stst is made
Been told various solutions..PCB, Ignition board, various thermo couplers etc..
Which should I change first..boiler only 2y old
Fridgegod
Hi, is the water flowing from the boiler towards the radiators getting very hot at the point when the boiler halts, or does it remain cool.
Before you spend a lot on new PCBs I suggest you engage a competent boiler engineer to correctly diagnose the fault for you.
I have not seen your boiler but the PCB is the last thing I would suspect.
Tony
