Ravenheat combi-boiler CSI85AT
6 Aug 2013
South Glamorgan
There appears to be no air coming from the flue to activate the pressure switch. (the pressure switch works with gentle pressure blown down the pipe) the pipe is clear and no blockage appears in the flue when air blown into the flue. the fan works ok Will there be a problem inside the flue?
Being part of the combustion process no one can advise you other than to call out a heating engineer.
