Ravenheat Condensing Combi's.......Any Good?
Biasi does not seem to be a registered trademark ( for boilers ) but their model name Riva is!
Tony
Agile said:
"""Bearing in mind I only have a budget of about £1200 to supply and fit what would you suggest ?"""
I would suggest that you save up another £300 and get a 28 kW boiler installed properly on a clean system!
The Biasi pump which Micky changed will have failed as a result of a dirty system and not the Wilo pump becoming faulty.
"Modifying" the standard Wilo to fit the boiler will not result in the full flow rate being achieved as the inlet will not be properly coupled. Its not a manufacturer's approved part and could get you into trouble if the customer is not made aware of whats been done and charged at the lower price.
You dont have to pay over £99 for a replacement pump for the Biasi if you know where to get it!
Tony
It was the same pump head. It was exactly the same. The rpm and pump head (m). Maybe i don't know where to go fot a spare for a Biasi but Parts center and o few other independant merchants were quoting simular prices. Your right about the dirt in the system doing this to the pump but I never fit the boiler so not my fault about the dirt. Boiler is out of warranty by a mile anyway so not going to affect warranty etc.
My point was cheap boiler.....expensive parts.
