Hi, can anyone help please? i'll be eternally grateful!
I've got a ravenheat rsf 100et. Whenever the water pressure drops below 0.75 (ish) the pilot light then refuses to relight.
The current state is that as soon as I try either the hot water or the heating, the pilot light warning light comes on straight away. In the past when this has happened, leaving it for a few minutes and then trying again worked. But alas, this time its not playing nicely! in the last few months, in order to fix this, its had a new circuit board, air pressure switch has been checked, and a new valve. As I said, usually leaving it alone works but I did get someone in to check it as obviously something wasn't right and it was then that a new circuit was installed. This hasn't fixed problem and I'm open to ideas as to what i should try next.
Thanks for spending the time reading my epic and thanks also if you're able to help
