RCBO - ??? - Wylex Consumer Unit
7 Dec 2009
Hampshire
To start, I don't have any intentions of doing this myself, I just want some clarification so I don't get fleeced when it comes to getting the work done,
I currently have a Wylex 10 way split load consumer unit, it's not the latest 17th edition version with an RCD on both sides, it's a couple of year old model, with RCD protection only on the side which the sockets are connected to. However, all 6 ways are being used on the protected side of the unit, but only 4 are being used on the unprotected side of the lights.
Plan is I'm getting a small hot tub put in the garden, and I need a direct feed with a 20 amp c type breaker connected to an rcd.
as the RCD side of the board is full I see a couple of options; but I don't know what is the best solution?
a; I'm wondering if I had an 20 amp, C type RCBO installed into the main board on the non RCD protected side, does this RCBO act as an RCD as well? therefore not requiring me to go down the route of option B or C below.
b; I get a small 2 way consumer unit (like a garage one) with RCD added which is connected to one of the spare MCB's on the non RCD protected side of the main consumer unit.
c; I get a completely new main consumer unit installed which has capacity for what I need.
Any suggestions would be gratefully received
Paul
All three ideas will work, C being the most expensive.
However, are you sure you'd want to have the RCD in the house?
Is the hot tub open air or in a cabin?
Will you need lights?
Maybe the RCD would be better in the cabin?
The sparky might start waffling on about 'exporting earths' and stuff.
Get someone round, listen to his proposal and post it here if you're not sure.
I wonder if the irony of climate-change induced adverse weather affecting your enjoyment of a completely unnecessary item which contributes to climate change is lost on you.
And exactly how many of the items that we use day-to-day could we really get by without? If the guy wants a hot tub then let him have a hot tub.
Some.
Quite a few.
And in extremis probably most, as our children and grandchildren will find out.
But some are more unnecessary than others.
No, not until we get personal carbon allowances. Then if he wants to heat a big open tank of water for fun instead of heating his house, or eating cooked meals, he can do what he likes.
holly crap, the bloke wants a hot tub, not open a coal fired power station.
Just for that I think we should ALL get hot tubs... Global warming is a myth
My garden gets quite cold in winter. So, I'm thinking of installing some radiators in the flowerbeds and some under-grass heating. Since this will all be wet areas, do I need to run an earth lead back to the CU? :wink:
