Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a number of Trade stands each protected by a 13amp plug in RCCD / RCD. Each time the main floor sockets in the venue are turned off the trip operates. Can anyone advise of a device that does not trip due to loss of power
It sounds like your RCD is an Active RCD which will trip in the event of mains failure or removal. You will need to manually reset after power has been reapplied. This type of RCD is generally used to stop certain items restarting unexpectedly
A Passive RCD is mains failure proof. It will function under normal conditions but won't trip in the event of mains failure.
Maybe all RCD plug-in adaptors are of the Active type? I really don't know as I've never bought nor used one.
That's ideal for him.
I did have a quick search around but only turned up active (non-latching) RCD adaptors. Good to know passive (latching) adaptors are available.
