- Joined
- 11 Feb 2007
- Messages
- 76
- Reaction score
- 1
- Country
In the bedroom I have a wall mounted AC unit, its a small unit and runs from the mains. Problem is the nearest mains outlet is behind a cupboard. I intend to run a length of flex from the socket (connected via a 3 pin plug) and then connect to an RCD protected FCU somewhere close to the AC unit then from that to the AC unit. The reason being I want a safer means of isolation than the hidden socket outlet.
Question is it ok to connect to this RCD protected FCU from a socket outlet using a 3 pin plug. Normally I would just spur from it but its chased in and would take forever to make right.
