Hi Everyone,
I wonder if you can point me towards a solution to my problem?
I have no experience with wiring and the homecare electricians I've called out so far have not fixed the problem.
I had a 9.5kW shower installed for around 4 years. In the last few weeks tennants in my flat noticed 5 mins in to a shower and the RCD circuit was tripping taking the shower and sockets off.
(From the picture above - it was and is the large blue RCD that is tripping and not the actual shower circuit which is no1 on the picture. no1 was switched off in the picture by us )
I'm with BG Homecare and had an engineer sent out. I was advised the 9.5kW shower was too powerful for the cable in use. I asked why it had been working for 4 years and I was told that it had been made to work by putting a 40mA RCD on the circuit to accommodate it.
I've replaced the shower with a 8.5kW model hoping this would solve the situation. Unfortunately my tenants have reported the same thing happening.
I went over to see myself and I had the shower running for 15 minutes on two occasions, but sure enough on the third occasion the circuit tripped after the shower had been running for maybe 5 or 10 minutes.
As the shower was not constantly tripping I advised the tennants to keep a record of occurences until I could investigate further.
The tennants have since had reports of the circuit tripping with the shower off once and now they can simply trip the circuit by switching the power to the shower on. (The ceiling switch)
I have had an electrician from BG back and he's not really been much help. He told me the 40mA braker should be donwgraded to a 32mA one - but as it is a WYLEX fuse board his company won't do this and he'd have to change the whole fuse box.
He replaced the ceiling switch as he thought it could be steam in the electricals (something which we had previously ruled out).
Still - as soon as the ceiling switch is turned on - even if the shower is off - the RCD trips. I'd say this also ruled out "steam in the switch"
Now I work out that an 8.5kW shower needs around 35mA protection, meaning a 40mA breaker would be right for the job. This however seems to contradict what two BG electricians have told me.
I definattely need to get another electrician out - but I'd like to be a bit more clued up as nothing is making much sense so far.
Thanks to all
Dan
