Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
i am currently fitting a shower pump,and the instructions state it needs to be connected to a 13amp fused spur,can i use a 13amp rcd plug in a standard socket instead
any sugs
thanks
RF Lighting is saying that if the manufacturer says it should be connected via a 13A fused spur, then that is how it should beconnected. it does not mean though that it should have a 13a fuse. The fuse rating will depend on the item itself
