RCD side or Not ?
28 Jul 2005
Hi Guys,
I have am finally going to upgrade my fuse board to a CU and have an electrician calling around at the weekend for a provisional look.
The house alarm and outside security lights are currently sharing the same fuse and now is the time to split them onto two separate mcbs. I'm going to get the alarm put on the non RCD side. Considering that the lights are outside, would it be better to put them on the RCD side?
Also, the room where I have my computer has it's own socket radial. I was thinking of getting this circuit moved to the non RCD side and protected by an RCBO. Is this a good idea?
Thanks,
Bothy
bothyhead said:
Hi Guys,
Thanks,
Bothy
would be a good idea to put the outside lights on a RCD. as for computer, i would just have it on the ring main. computers dont leak much power and unless you have a room full of computers then your unlikely to trip the RCD
Thanks for the quick reply Andy!
I was thinking more along the lines of ... if any other earth fault in the house trips the rcd, then at least the PC won't be brought down as well - and I will have time to shut down gracefully.
if your that worried, you should get a UPS. much easier. and they also last if there is a blackout
