Thank you both for your contributions. I have had the pump apart again, the impeller does seem a little damaged but no stones. I am puzzled because I have a RCD (?) in the conservatory leading to twin sockets outside for the pump and filter. When I plug these two in the outside sockets, they trip the RCD. But, if I run the pump and filter on an extension lead from a socket in my house, they both work. I am told by an electrician that there is nothing wrong with the sockets outside and the RCD. He thinks a fault in the pump may be causing this. I really don't know which way to go, get another electrician in or buy a new pump. I wish I had a crystal ball! Many thanks again.
