I have a problem. I have a split board with common earth and neutral bars. The incomer is just a normal switch but the power side is covered by an RCD. The lighting side has rcbo units for each circuit. It all looks a bit of a mess but appears sound other than that.
I have added some outside lights on the lighting side via an mcb which feeds an rcd (the type with a 13A fuse in it). Problem is, when I power the circuit up the main power side rcd trips straight away.
I have also added some rcd sockets to the power side but have not actually tested them with a load yet, is this likely to cause me problems too?
