I've done a bit of research on here and this subject has come up a few times but not quite like this . I have a house (not unusual there) and a garage/workshop some 15m away. I have an RCD protecting the house circuits and the SWA cable feeding the garage /workshop and then another in the workshop CU. Reading up on this, it appears this is a no no under the regs and you should never have two RCDs in series. The problem of two in series is both trip when you get a fault at the garage end, so if I get a trip in the workshop I also trip the house. This could be cured by taking the RCD out at the garage end and replacing with an MCB. Problem is I'm not always on site (in the house ) when the garage is in use so it would be a problem if the house trips. How can I get around this one?
A thought I’ve had is to put another earth electrode in at the garage end but if I do this would I connect it to the neutral in the garage CU???
Thanks.
Thanks.
