I have studied boilers for a while now and have been in correspondence with the tech. adviser at a well known manufacturer for a week - but am still none the wiser. The previous owner of the flat had electric heating and I am beginning to think no gas boiler can be used in this property for heating only. However I have already installed gas and mains water to the flat - to supply gas central heating.
I require ONLY heating - as in radiators - as the hot water is supplied from the block's communal boilers which I have to pay for whether I use it or not. (I have also installed an electric shower)
1. The space where the boiler can only be fitted - i.e. a solid wall - is very restricted. But there is enough space for a small (in size) boiler and it is an exterior wall. This is not the problem.
2. The problem seems to be there is no room for a cylinder or expansion tank - as I am in a flat and these cannot go in roof ( or anywhere else). I am being told one of these will be required. Is that correct? Also I am being told I will need a pump in addition to boiler and expansion tank! But no where to put pump either!
Any info as to any suitable boiler that can contain all requirements within itself for heating only - much appreciated indeed!!
