re-pressurising sime format -how??
7 Jun 2008
Hi, need some help with this one please.
Lady next door has no heating. I've looked and the pressure guage is at zero.
However, i cant get it to fill and she has no instructions. Underneath the combi on the cold inlet and heating return i can see 2 blue plastic knobs. A small filling loop connects these. Turning both of these has no effect. I loosened the filling loop where its screwed into the check valve on the heating side and plenty of water began to drip.
Is there something i'm missing or do the filling valves on these seize up. How do i fill this combi??
Many thannks.
hi i would check to see if the plastic tops are actually turning the shaft of the valve as these can sometimes seize and the plastic top turns but does not turn the valve on, also the double check valve can seize up i have had 1 that has done the same and no water would go into the system
mick
Valves on these are prone to seizing. From what you say it seems as if the inlet valve is stuck open as youre getting a flow of mains water when you loosen the filling loop at the checkvalve. As gasmick says it seems as if the checkvalve has seized.
Could you add an external filling loop to the pipework below the boiler??
