I'm trying to lay solid wood flooring on wooden underfloor. As the underfloor planks are running towards the window (just as my floor should at the end), I believe I need 6 mm plywood sub floor to be screwed to the underfloor first.
I also plan to lay 5 mm fibre underlay for sound insulation, these are the big green sheet from the big DIY retailers for £20 a pack. As I found they are suitable for laminate and for real wood flooring as well.
I found controversial information on the internet whether I should glue, nail or leave float the flooring, and unfortunately I have no guidelines come with the flooring I bought (125 mm width, 18 mm thickness, various lengths, hand scrapped solid oak).
One advise that solid wood should be glued to wooden underfloor only, but how can I use fibre underlay? I don't think that should be glued?
I would prefer to float it, as it will be fiddly due to the various board lengths and various board widths(about 3 mm tolerance).
What are your thoughts on this?
