Rebated doors
31 Mar 2006
Leeds
Greetings.
I'm wanting to install two doors into an opening. I'm looking to install one normal width one for day to day use, and then a smaller one which can also be opened if something large needs to be brought through the doors.
Normally these seem to be rebated so they have a good place to meet in the middle.
Is it normal to buy a rebated set of doors, or do you buy normal doors and put some wood on to form the rebate?
I'd probably want to use something like a 1/2hr fire check door. It doesn't really need to be fire rated, they just seem a lot more resilliant against day to day knocks and bashes etc.
Thanks to anyone who can help.
do you really need a rebated set of doors?
can you not just have 2 doors,1 (slave)with a cleat attached to it to mask the gap?
then you could fit 2 no flush bolts to it,saves you fitting a rebate set lock/latch.????
