Hello to all,
I have recently had a conventional open vented boiler replaced from an Ideal Elan to a Baxi Solo 15.
I am looking for an independent view on whether or not the problems i can see are actually problems before I chase up the installer to rectify.
The installation uncovered the problem of the original pipework flow and return being installed the wrong way around. This was picked up by the flow switch on the new baxi.
Consequently the flow pipework now has a series of elbows running from the top of the boiler a horizontal run (that is not level, running down) and another 90 bend up to the previous return; that is now the flow.
Problems have arose, such as air in the system.
The main install questions are
.Is the pipework safe being routed from the boiler with a series of bends and does this have any implications on the safety aspect of overheat etc?.
Condensing Pipe runs into washing machine trap?
Outside flue diameter casing being rubbed against by pipework?
Gas pipe has no isolation valve or I.D tape, rubs against boiler casing?
Sorry for the long winded post.
Any advice would be greatly appreciated!
