I have read a good guide for fitting recessed manhole covers on pavingexpert.com, but have some questions.
I am not sure yet if the cover will involve cut flags, I may be able to trim one to fit. Almost certainly I will have mortar gaps to fill. I plan on using brush in resin. I will be laying the flags on full mortar bed sharp sand/cement (also slurry priming the underside of the flags), so this will cover the entirety of the recessed cover before the flag/flags are placed into it.
It seems that most flags placed in the recess are cut to butt up to the edges of the cover and only have mortar gaps if this means alignment with the general patio around it - is this the case or would some resin be expected to fall into what appears to be a very thin gap?
Where does water go that drains into these gaps, of course sandstone and the resin are to some degree also permeable. The full mortar bed would surely class as impermeable so water would not need to drain through that into the drain. It seems if you fill these covers with gravel or similar you would typically drill some holes into the recessed cover?
