Hi Im after a combi boiler for a chalet/flat its got to be LPG and also have slot-on cordless room stat (saves on wiring digs) apparently Valliant do one??
Although where combis are concerned the distance between dear & cheap is greater than that between good & bad. In other words, even the dearest ones can be f******g c**P with expensive parts etc..
