Recommend a Room Thermostat
4 Jan 2009
Herefordshire
Can you recommend a digital room thermostat that :-
* Does NOT run off batteries
* Allows different temperatures at different times of the day,
THanks
You need a programmable room thermostat. I've never seen one which does not require batteries. Why do you need one which doesn't?
Considering its connected to the mains I don't want to be bothered having the change the batteries in it.
from day to day working with them I've never seen one that doesnt. Even the wired ones for some odd reason use batterys to work the display and relay, although the good ones you literaly only need to change batterys every 2 or 3 years, and for the sake of 2xAA's I'd go with that before finding some unknown/obscure one that doesnt need them
there might be some but its not common.
