Recommended Hikvision cctv system/kit
4 Dec 2011
Merseyside
Hi there
Does anyone recommend a decent supplier and kit for a 4ch Hikvision IP cctv system (wanting to stick with Hikvision as the intercom is Hikvision too)
Many thanks
can't comment on appropriate kit as dont know your requirements.
you can spend pretty much anything, you may over spec or under spec.
Every system should be specified to the job they are to be used for, not buy a kit online of all the same cameras without at least checking that the cameras will do the job they want.
if you over spec then you should be future proofed but it probably cost you more than it could of done.
Under spec and you will be disappointed and wanting an upgrade, and then you will find the NVR needs upgrading to cope and a bigger hard drive to get decent storage amount and that could end up costing more than the original over spec.
