Recovering Shed Roof Felt - Galv nails or Adhesive
13 Jun 2005
Monmouthshire
My shed roof felt needs replacing.
Going to replace the OSB boarding with Plyboard (2.4 x 1.2 x 2).
So I'm using B&Q Green felt to cover the roof.
But which would be best to attach the felt, Galv nails or felt Adhesive.
If adhesive is suggested, how much would cover the roof. 1 or 2 ltrs. ??
I always use nails but often because im not replacing the boarding and its damp/dirty. If your putting on nice dry clean boards then adhesive might be good. I'd imagine you'd need more than a litre though. more like 5 at a guess. hard to work with at this time of year too perhaps.
I used bitumen to bond the under felt to my shed roof. I also used bitumen for laying the mineral felt over the under felt, but also hammered galv clout nails through as well. I was uncomfortable putting nails through the felt, just seems wrong, but the felt is supposed to seal around the nails. I haven't had any leaks, but I guess the bitumen is giving an added seal?
I laid the under felt vertically so it was going up one side of the roof, over the top and down the other side. I then laid the mineral felt horizontally along the length of the roof.
