I was discussing our extension plans with my brother who's a civil engineer (not structural). We'll need piles and beam & block flooring due to clay soil, trees within 2m of foundation and FFL between 600mm and 1200mm above ground level.
I was explaining that I understand the ground beam is a lot of the cost. He suggested it would be much cheaper to extend the piles above ground up to say 450mm below FFL, then to span the piles with steels and build directly off them. He thought steel would be much cheaper than the cost of the ground beam and have ample strength.
Would this work and is it ever done? I haven't got an SE yet as we are at planning stage. I would need 16.4m of either beam or steel. A set of four 203x102x23 UB with a 275x10 welded plate would be about £1.5k or 250x250x10 SHS would be about £2.5k. Obviously I don't know what beam would be needed for a 3m span but either of those is a lot cheaper than a ground beam. The extension would be single-storey, conventional construction with gable pitched roof.
I guess you would still need the outer skin to go below ground level for comestic reasons so what would you do there? Clad with cement boards and slips? Any sort of brickwork would presumably need a foundation so then you're back to step 1. You would also need to restrain the steels somehow e.g. shot nailing or bolting into the piles.
