Reformatting
24 Dec 2003
Does a Full Reformat of a Computer Clear The Registry?
Windows help gives you the following info on serch of: reformatting disks
To format a disk
If you are formatting a floppy disk, insert the disk into its drive.
In My Computer or in the right pane of Windows Explorer, click the icon for the disk you want to format.
On the File menu, click Format.
Notes
Formatting a disk removes all information from the disk.
and
Caution
Formatting a disk removes all information from the disk. Your computer may not function if you format the disk (usually the C: drive) on which Windows is installed.
Should think so ;)Why do you want to do that? Norton etc has fixes for Registry
It doesn't just clear the registry. It clears the entire partition. I should explain that hard disks can be partitioned into many parts so one physical disk can contain many logical disks. If you reformat your boot drive - usually drive C: - you will lose everything on it; the registry, your documents, your operating system, the lot. Next time you switch your computer on you will get a meesage along the lines of "Non-system disk or disk error" This is BIOS speak for "Where's the b****y operating system gone?" You will have to reboot from a floppy disk or CD and reinstall your operating system. Is this what you want?
Just for the record, reformatting doesn't actually delete much. It just marks the space as empty. The same thing happens when you 'delete' a file. If you really want to clean a disk - which is always advisable if it came from an unknown source and you don't want to be Gary Glittered - do an UNCONDITIONAL format. Boot from a DOS floppy and enter FORMAT C: /U.
