RegalSafe RS50F Installation/Engineer's Manual required
18 Nov 2015
Sir,
I had a power cut and my burglar alarm went haywire.
It seems that the most likely problem was that I needed to replace the battery.
I bought a new battery and replaced the old battery and pressed reset but I still cannot either clear the fault lights or activate the alarm.
The alarm panel is a RegalSafe RS50F.
I have been advised that when this panel loses power from the battery it has to be reprogrammed but the only manual I was given by the Installer was a very thin user manual.
Unfortunately that company has now ceased trading.
It seems that what I need is either an Installation Manual or an Engineer's manual.
Can anyone help with some advice or point me in the direction of the elusive manual?
I fully appreciate that this is an old system and that modern ones remember the codes so this issue doesn't occur however this is the first problem I have had with this system so I am reluctant to replace it when presumably a new battery and a reprogramming will fix the issue.
Thanks very much
Barry
I don't think so, guess the 'friend' is not an alarm eng. who knows the RS50F, or for that matter an alarm eng. even panels of the age of the RS50 have non volatile memory
May have one , will get back to you
Some of the regal safe panels had an on board battery to save the programming but it's probably past its sell by date !
I've found I have a .pdf, need an email to send, how about putting one in your profile at 18.45 for 5mins, I'll send it?
or give a time, i'll be around on/off this evening
Europlex,
That's great.
I think I have added my e-mail address to my profile.
If I haven't done it correctly please let me know.
Thanks very much for your time and trouble.
Barry
Barry, sorry for the delay, family not well, had other things to do.
Europlex
  • RS50F Installation Manual.pdf
  • RS50F Installers Guide.pdf
Europlex,
I have received one Manual (thanks very much) but I have a query.
I have sent you an e-mail a couple of days ago because this query was specific to the e-mail you sent me but if you prefer I have no problem in putting it here.
Barry
Europlex,
Mission successful.
It was a bit of a struggle but I have now managed to get this reprogrammed successfully so thanks very much for your help.
I don't know exactly how the "Thanks" facility works.
On your last post I clicked on the "Thanks" but the number didn't rise from 232 to 233 as I expected.
I tried again and the same thing happened so maybe it updates overnight?
Anyway if I have messed this up and it is important to you please let me know what I should do.
Once again thanks to you and of course the forum!
Barry
233 it is now, thank you, no real need to do it, it's just nice if you do.
Did that make sense? What the h**l, thanks any way, you managed it (y)
