    Dismiss Notice
Regs for fire break
Discussion in 'Building Regulations and Planning Permission' started by Lostdog, 15 Jul 2020.
  1. Lostdog
    Lostdog
    15 Jul 2020
    24
    Thanks Received:
    Country:
    Between 2 floors in a flat
    So I've got 12.5mm existing plasterboard ceiling, I should imagine this is normal plasterboard, I'll be putting an mf suspended ceiling in below this with 50mm isover acoustic roll and 2 layers of 12.5mm 'sound block'
    I'm out of fireline and have too much sondblock and sure I've read 60 mins fire break between floors, so the above would be more than enough?
  2. Sponsored Links
  3. frutbunn
    frutbunn
    22 Jun 2020
    837
    Thanks Received:
    155
    Country:
    1 hour in most situations, what height is the floor above ground level.
  4. Lostdog
    Lostdog
    15 Jul 2020
    24
    Thanks Received:
    Country:
    If I've understood that correct, ground floor, floor level to first floor, floor level approx 2.9M
  5. frutbunn
    frutbunn
    22 Jun 2020
    837
    Thanks Received:
    155
    Country:
    I hour,s OK, its high rise stuff that requires a higher standard.
  6. ^woody^
    ^woody^
    3 Sep 2006
    33,586
    Thanks Received:
    4,565
    West Mids
    Country:
    What does all this mean?
    One flat, or separating two individual flats?
    If you already have 12.5 ceiling, then what is the current status, ie if this is acceptable now then what is the actual problem?
  7. Lostdog
    Lostdog
    15 Jul 2020
    24
    Thanks Received:
    Country:
    There being converted, sorry that bit of info prob would have helped, so first and second floor will become two seperate flats, own electric and water, shared stair well and front door.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
