regular vs system boiler
21 Nov 2009
London
i am stuck. I want a condensing boiler no deeper than 310mm. Only ones I can find are regular boilers. Should I comprimise on cosmetics of my flat to accomidate a (bigger depth >330mm) system? what do I lose by going regular boiler?
many thanks, G
I guess the pump valve etc go in airing cupbaord with megaflow. Which will be quiter system or regular? - I have to locate in bedroom - which one will walke me up?
I dont know why you have started a new thread!
Its normal to put the pump by the cylinder with a heat only boiler.
PS, I thought a "regular" boiler was a non-condensing boiler?
sorry I should say its a heat only. So if i understand - I put the pump / expansion vessel remotely with cylinder and boiler in void on its owm?
system boiler = heat only boiler which contains, a pump, expansion vessel,prv and gauge
regular boiler = heat only boiler and is open vented
do try and keep up Mr Glazier
:wink:
