Rejuvenating a flat roof
5 Dec 2010
Mine was leaking and I painted the area with bitumen primer.That seems to have helped but I wonder whether I can use some horticulture fleece in conjunction with the primer (maybe a coat or two)
A roll of fibreglass matting would be better but I have the fleece to hand and I think it might work with the primer and be easy to apply.
OP,
Why not post pics of the leaking flat roof surface, and the ceiling below?
Fleece is not suitable for binding tar and will break down rather quickly.
There a few, if any, lasting paint-on solutions to roofing issues. You are best leaving well alone rather than create an extra headache for the flat roofer.
I used 'Acropol' some years ago on a suspect flat roof - it survived at least 7 years without issue until overlaid with EDPM last year. Unfortunately you have used a Bitumen product which does cause problems with being overlaid with Acropol or similar. I think your quickest/cheapest solution is roofing felt laid in 2 layers bedded on hot bitumen pitch.
The thread is old now but I just found this by doing a search on "reemay" ,which is the American term for the fleece I was talking about.
It seems to specifically claim the horticultural fleece is a suitable material for roofing and lists the petrol related products that it can be used with without degradation.
It won't let me copy/paste but days it can "replace fibrrglass matting or otganic roofing felt"
I did use it for a small patch (about 18 inches square) ,doubled up and using a bitumen based primer to soak into it and to stick to the torchon felt .
It seems effective but it is just a few months old and so I can't say how permanent it is (it feels good)
