Hello. New to posting on forum. I've read a few posts and the boiler change FAQs etc.
We have a 17yr old system which is fitted with a Thorn Olympic wall mount. It was £40 when fitted and at least 5yrs old at the time. This was on advice of a BGas engineer who said it was built like a tank and would likely outlast a new boiler. True to his word it never needed any repairs and untill an unreliable pilot and a very slightly pourous water jacket (only when stone cold) in the last month it has been great.
So time to replace and I want to fit the new boiler a couple of metres to one side in the same room. We have a system with loft header tank, vented hot water cylinder, pump & 3-way motorised valve near cylinder, room stat & digital programmer in hall. Boiler is only gas appliance in the house and supply is 22mm to within 1m of boiler.
I want to keep to a standard boiler on the same system so the replacement is as straightforward as possible.
As cash is tight (but no cheap bodges wanted) I would plan to physically hang the new boiler myself and do the new flue hole plus run the new heating water pipes to it. Then I'd get a qualified engineer to powerflush the system and connect/ commission.
At the same time I would want to dry line the existing solid double brick victorian wall with plasterboard on timber battens. I assume this is OK as most modern houses are dry lined.
So 3 questions please...
Are there special regs or practical considerations for fitting a boiler to a plasterboard wall?
As I can look up the heat values for all the existing rads in the house by their size how do I use this information to work out the boiler size to include the hot water cylinder?
Any thoughts on a quality new standard boiler that will connect to my existing system and controls with minimum fuss.
Any other thoughts on my idea of how I want to do the job?
Thanks.
Thanks.
