I need to reline a ceiling because the surface - previously covered in polystyrene tiles - is so bad. The shape of the room, hallway, would suit laying the boards long edge along the joists. Not the best way to do it but I wonder if anyone has any advice? Should I go ahead or just accept more wastage and more joints and lay it in the "right" direction?
I was thinking about using foam adhesive since the joist spacing is quite large. Is it any good?
http://www.toolstation.com/shop/Adh...l+Foam+Fix+Gun+Grade+750ml/d180/sd2857/p60449
