Hi all,
Have some issues last winter in my loft with 2 my heaters there not heating entirely, I mean the bottom of the heater gets hot but not the top.
I bled them but did not change the issue. did a bit of research and read that I needed to increase maybe the water pressure. I looked at my boiler water pressure indicator and there, I already have a question : There are 2 arrows in my boiler indicator, 1 black and 1 red, which one is the water pressure ?
the black one stays very close to 0, even when I open the taps of water filling (I can hear that water arrives in the system and I could verify this as my 2 top floor heaters starting to **** water as I had the heater bleeding cap opened, whihc I closed obviously when it started ****ing water)
The red one is a bit under 2. I would think the red arrow is my correct indicator of water pressure ? Interesting to see that I cannot fins this information online ??
Anyway, I thought I did the right thing, I restarted the boiler and effectively heaters are now heating properly...but a new issue came into the equation : the boiler heaters flow connexion at the bottom the boiler started to leak...
I have also a bit of leaking on on my water inlet taps (red and blue on water taps pictures) also, I'm not fully sure in what position should be the blue tap.
I know loads of question but the main one is : Does the leak from the boiler heater flow connexion is something significant or more precisely dangerous ? Should I try to rescrew things on that flow connexion ?
then which arrow is the water pressure indicator ?
and to finish : are the drip leaks around water taps are normal or I should find a boiler man to check all this properly ?
thank you very much, I'm newb , just trying to DIY
