Remote control lighting?
22 Jan 2007
I have a garage approx 25ft from the back of the house.
I would like to be able to turn a couple of external garage lights on and off from inside the house (and preferably from my car aswell as its a long unlit lane upto it)
Are there any products like a remote control relay idea you can recommend that could run say 500w that would come with a couple of key fobs that can be used to turn lights on and off at a distance.
jj
If I understand the OP, the lights etc are external to the garage.
Where would you put that plug in module? It would have to go inside the garage. Would it work from 25metres away with the garage door closed?
I think not.
Browse through this website.
http://www.rfsolutions.co.uk/
A lot of their products can be bought via Farnell and similar retailers.
If the drive is long and the key fob may sometimes be used inside a car then have a receiver at each end of the drive and hard wire them to a timer and relay controlling the lights.
jj
I think not.
Obviously he will have to connect the lights via a socket & yes I've used one that went through 2 foot thick stone wall from 25metres.
