Remote control of outdoor led lights
10 Dec 2008
Jersey Marine
I’d like to run a pair of LED light strings (fairy lights)
To avoid having to walk to sockets to switch on … would like to consider ‘smart sockets’
A Google around showed ‘BG Storm Smart Control’ as one option.
Is this the best option, or are there others to consider…. would be nice to have an App to control them, maybe interface to Alexa in future (but not vital). Simple remote control would suffice.
Not sure what that is do you have a suitable link ?
Have plenty of sockets in an outbuilding, had thought of adding new one ... but open to other plans.
Do you mean like one of these - or is there a better option ?
That would work, but you have to buy a Quinetic switch as well.
Buy one of the SmartLife/Tapo enabled smart sockets then all you need is an app. Or Amazon smart socket. All controllable from Alexa If you want to go there later.
Is that SmartLife rather than Quinetic? both new to me sn not sure what fits/works where
Anybody aware of a primer or similar so I can get myself up to speed.
SmartLife is an app for a smartphone.
It can control quite a lot of smart sockets.
The Quinetic smart socket is a separate solution. Quinetic smart sockets work with a Quinetic smart switch. So you’d have to buy two things.
You can link Quinetic to WiFi snd hence to smartphone/Alexa. But you’d need a Quinetic wi-if receiving controller.
For what you want to do, go for a cheap smart socket.
Thnx ..I'll do some searching on SmartLife.
Presume the one I mentioned 'BG' is another bespoke format.
Need to choose the right one :-)
Before you commit yourself, make sure to read the negative reviews on Amazon. It's interesting what you may be signing away by using the app.
I have a number of devices controlled by SmartLife.
I have had no negative problems.
The BG stuff appears to be proprietary.
Re EXTERNAL sockets. Bear in mind that they only waterproof when the front cover is shut. A lot of LED string lights come with a chunky “wall wart” power supply plug. You can’t close the cover with most of those things.
Simple solution is a plug in smart socket rather than changing your socket
The plug-ins have the advantage that when they occasionally crash, as they all do seem to do, you can just unplug/switch off the power to the Smart Plug, to reboot it. Built into the socket, you would need to use an alternative way to reboot it.
