Hi all
I have a double glazed window with a white panel underneath which i Would like to remove because I don't think there is any insulation in there. Before I moved in to the flat there used to be a door leading to the Balcony and for what ever reasons it was removed but the previous occupants did not brick up the gap they covered over it with wood (plywood I suspect) I know this because when I lean on it it flexes. The easiest way would be to remove the wood I know but my other half does not want to redecorate but complains the room is cold. Which only leaves me with trying to remove the window cill or the white panel outside under the window or listen to my other half complain.
Can anyone help?
Can anyone help?
