There are a number of various fittings that have fluorescent tubes in, not all remove and install the same.Would someone please tell me if there is a trick to removing theses small fluorescent tubes?
JamesEB
What does that mean. Did it rotate or did it not.I have twisted it but it won't budge.
Yes, it is exactly the same as the original and is seated correctly.Is it the same length and wattage as its predecessor and is it seated correctly?
If so, it might be best to take it back, get a refund and replace the unit with one using LED which will be more reliable.
What was the original reason for replacing the tube
