I need to remove and replace a boss which is solvent welded on.
I have seen advice on the net that for solvent welded ones you can try using a chisel and a heat gun.
Has anyone managed to do it successfully without ruining the pipe?
Also I would image the solvent weld originally would have damaged the pipe - how do you clean the pipe up to make another connection? Sand paper?
