Removing an Outhouse
12 Mar 2008
Yorkshire
I live in an old Victorian terrace that has a row of 4 brick outhouses at the end of the garden. Access to two of the outhouses are from my garden and the other two from my neighbours garden on the right.
I have a legal agreement with my neighbours on the left to knock down the two outhouses that lay on my land.. Our deeds have been updated and everything is ok in that respect.
I plan to begin knocking the two outhouses down next week but wanted to check to see if there is anything I should be wary of.
The toilets have already been cemented and its literally the brick structure that will be coming down.
The row of 4 outhouses are all divided by a brick wall and sit on a concrete base. My main concern is that I obviously don't want to damage the two outhouses that will not be knocked down.
My plan was to remove the wooden roof structure first and then start removing bricks from the outhouse furthest away from the two that will remain.
Where the join is between the two outhouses that will remain is my main concern as there will be a few bricks that span both outhouses.. any tips would be much appreciated
I no this is hard work but the plan is to reuse the bricks to build a small wall... probably need 500 bricks max... I've tested the mortor and its pretty old and have given myself over a month to clean up up the bricks. Ideally i would have bought the bricks but have been unsuccessful in matching them.. but thats another topic.
any advice would be much appreciated.
you may have to tooth out every half brick and re fit a complete return brick, laid in mortar.
