- Joined
- 5 Nov 2008
- Messages
- 194
- Reaction score
- 3
- Country
Again our (expensive) Blanco sink is leaking from its (expensive) waste fittings. Unfortunately this time I cannot shift the threaded bush that holds it all together. What's the best tool to use as even my biggest flat bladed screwdriver is too small to span the hole.
This is the second genuine Blanco waste kit to fail in less than 5 years so if/when I do get it out I would like to replace it with another manufacturer's design that hopefully performs and lasts as well as the £5 kit I fitted to the sink in the utility room many years ago.
I guess it will mean replumbing under the sink because IIRC the Blanco waste pipes are a different size to UK standard, but are waste systems basically interchangeable, or am I stuck with Blanco?
TIA
Mike
TIA
Mike
