I'm trying to fitting a Blanco inset sink to a laminate worktop. The hole in the worktop has been cut and sealed.
The underside of the sink has a blue flexible seal around it about 1-2mm from the edge, and the instructions show to apply sealant around the hole, seat the sink on it, then tighten the clips. The blue seal thus sits on the bead of sealant.
Unfortunately, once in position I found I couldn't access a couple of the clips so have had to remove the sink to make more access space.
It's a PITA, but what surprised me was how easy the sink came off the sealant. The blue seal was completely free of sealant, although the sealant on the worktop showed the seal had been seated perfectly.
Question - is this what is intended, ie the sink is not physically stuck to the worktop, or am I missing a trick here? is it designed to allow a bit of thermal expansion without damaging the silicone?
Any thoughts, hints, advice would be welcome while I remove the silicone from the worktop and try again.
TIA Mike
TIA Mike
