try steaming it with a wallpaper steamer, will make it melt of then u can chisel it of
Found out that a long handle scraper works a treat, the sharp blade cuts right in and under. The reason I'm removing it is because bonding plaster is hydrophilic and draws water through the brickwork which is not a problem if the bonding plaster is a fair way above ground level.
